I decided to polish the lips on my rims. I think they turned out pretty good. Any opinions? good or bad... let me know what you think...
Did it myself actually still on the bike took like 3 hrs... wasn't hard just time consuming. also doing a set on a gsxr 750 right now. guys paying me 150 for them to be polished like mine...seang_2 said:Did you polish it yourself or did you have someone do it?
3 hours for both? sounds like you made good time. looks good man, good work.RMSZX6R said:aircraft paint stripper... applied heavily... scrubbed with a hard plastic brush... more stripper... more scrubbing... more stripper... more scrubbing... then coarse steel wool... more rubbing... med steel wool... more rubbing... super fine steel wool... alot of extreamly hard rubbing... then I took a polishing wheel and an aluminum rubbing compound and used my high speed polisher on the lips of them... then cleaned them with eagle one rim polish...
Yea both and Thanks... power tools are awsome... trick is to alternate rims. soak both rims with stripper let set for 5 min. then when you scrub the first rim recoat before moving to the other then when you get done cleaning the other would have been in the stripper for a while and ready to be cleaned......... If I made any sense?...lolhoser said:3 hours for both? sounds like you made good time. looks good man, good work.
lol gotta crack on u juuuuust a bit (since u seem pretty cool enough in all ur other posts n hopefully u wont take it personally..)RMSZX6R said:It is faster...lol green is bone stock... no jumper with stock exhaust...
Black has: PCIII, modded stock muffler and removed butterfly valve, jumper mod, zip tie mod, K&N air filter and oil filter, rear res relocated under the seat, kietti tank pad, decals removed, custom bar ends, fender elem bracket, lp smoked VS shortstalks on the rear, polished rims, and blue nose light, rear brake spring removed, reverse shift pattern, I think thats all? Need a damn DB screen. Every time I go to buy one I just space out and end up day dreaming about go fast stuff...
the second set I just finished wasn't on the bike i didn't mask anything off I just used a small 1 inch brush and followed the line carefuly. The rough part of the rim is hard to strip paint off so if your careful and you accidently drop a little on the textured part you can wipe it off before it eats the paint...if anyone wants it done 100 bucks and you pay for shipping to and from... tires dismounted preferably but i can do it mounted too... just pm me if you want. once you check out shipping prices... But honestly its not hard just time consuming... and your hands will be cramping by the time your doneseang_2 said:What do you use to separate the parts that you want the stripper on and the parts you don't. Tape?
http://kawiforums.com/forum/topic.asp?TOPIC_ID=82251RMSZX6R said:I thought I saw a green 07 with polished rims on here. Does anyone have any pics of one so I don't have to change rims and tires again to see what it looks like on my green one?
